Peak Detection and Integration
I have been trying to design a reliable way to detect and integrate seven reactor zone temperature profiles. First, I tried to modify the peak 3.0 example to suit my needs, but alas, it does not work as envisioned (i.e it never detects the correct baseline with my data but it works with the peak 3.0 data set). Does anyone know of a reliable way to detect and integrate peaks of varying length in Labview? I will attach a copy of my vi in hopes of a solution. I attached a Savinsky-Golay smoothed experimental data set of one reactor zone. Thanks for your time!
(3,384 Views)
In general, I've found working with either the 1st or 2nd derivatives to be more reliable when doing peak searches.
2006 Ultimate LabVIEW G-eek.
(3,384 Views)
Hi could you find a solution for your program? because i'm really itnerested to find a program that can integrate the peak and find the area.
thanks 🙂
(2,743 Views)
