Peak Detector Algorithm
Anyone knows which algorithm used in the Peak Detector VI in LabVIEW 2011?
I used this VI in my code, and now i am mathematically documenting it, and needing more information about the method used by this VI to find the peaks.
Tanks!
(3,433 Views)
Read the detailed help.  It mentions fitting a quadratic to the peak.
Lynn
(3,426 Views)
Hi Lynn, thanks for your reply!
I read the detailed help, but i am looking for something more specific. There's nothing?
Grateful
(3,422 Views)
Did you also read the Dev Zone document which is linked from the detailed help?
I do not know of anything more specific. If you call NI Support, it may be possible for an Applications Engineer to get details of the algorithm from R&D if they are not proprietary.
Lynn
(3,418 Views)
