03-10-2010 05:50 AM
I am using the Peak Detector VI in the Signal Operation Toolbox in an attempt to report the peak values in a 1D array.
The array is shown plotted in the attached graph.
So, as I want to report the peaks which are located at 23MHz, 36MHz, 46MHz and 54MHz, I set the threshold to -90, and leave the width at 3.
However, it would seem that although the VI correctly returns single peaks for the values at 36MHz, 46MHz and 54MHz, it returns 24 seperate peaks between 22.0125MHz and 23.6625MHz for the peak at 23MHz.
If I increase the width parameter (to around 14), I can get the function to report a single peak at 23MHz. However, this has the unwanted effect of losing all the other peaks.
Any thoughts on how I could use the function to report a single peak at each of the desired locations?
Many Thanks,
Dan
03-10-2010 06:01 AM
Can you post the code you are using? You are perhaps using Express VIs and because you do not have any relationship to your data. You are confused about what to do. This is a very common Express VI problem. If you want the data for specific frequency bins. You just have to index an array. Here is some information for the FFT beginner.
http://zone.ni.com/devzone/cda/tut/p/id/4278
03-10-2010 06:03 AM
03-10-2010 07:08 AM
03-10-2010 07:16 AM
03-10-2010 07:21 AM
03-10-2010 07:37 AM
Here,
Should now be able to read in my text file.
Dan
