Peak/Valley detector vi: does one exist that I can import into Signal Express?
I'm not a LabVIEW guy per se so please talk slowly and use small words when explaining anything LabVIEW vi specific.
I'm looking for some sort of peak/valley detector vi. I'm sure it exsists in one form or another. In fact, this white paper talks about it but that may be part of a software suite I dont have access to. Also it only seems to pick out the waveform PEAKS, I need Peak and Valley since most of my testing is cyclic load/deflection stuff with changing stiffness (or displacement) over time.
My plan is to import this vi into Signal Express which I use exclusively for data acquisition and signal conditioning.
I do not have access to a LabVIEW dev suite, just Sig Ex on standalone DAQ PC's, so whatever the solution may be needs to be plug and play.
Thank you!
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(3,181 Views)
If you don't have a LabVIEW license, you don't have access to the analysis functions so I don't understand what you think you can import from. Perhaps you should post to the SignalExpress board. Not many here use that.
(3,148 Views)
In Signal Express you can import a LabVIEW executable if you have the runtime installed on that machine. Its pretty straight forward.
I was just asking if anyone is aware of an existing vi that would suit my purpose.
FWIW, we do have LabVIEW on a hangfull of machines in the facility, just not the ones I use, and I dont code in LV so beyond something plug and play I would need to ask for help from one of my collegues.
PCI 6281 DAQ card
Win7 Enterprise
(3,121 Views)
As the link shows, the peak detection and waveform peak detection have a selector for peaks or valleys. Check one of your colleagues LabVIEW license to see if it a full or professional version that would have the analysis library.
(3,114 Views)
