Peak detection on tracking basis
Hello everyone,
How can i track indiviusal peaks in a signal coming as an array.
I have already used the peak detector vi but it takes the complete array as an input, but i want to work on indiviual peaks.
Can anyone pls help me.
(2,458 Views)
You mean you have multiple waveforms as an 2D array? If so, you need to use for loop or index array to do peak detection on by one.
(2,442 Views)
Thanks for replying
I have waveform as 1D array, but the waveform in the 1D array vaires in its peak volltages and therefore the calculations changes, what i want to do is to track indivisual peak rather than the complete set of waveforms present in the 1D array.
Regards
(2,430 Views)
