Peak detection
I've attached an XY graph with a signal and a peak detection, you can see
that labview detects the peaks and valleys but i want the detection at the
beginning and at the end of a peak (where the arrows are), is there a VI for
this? or does anyone knows how to make this?
Thanks in advance, best regards,
Thijs
(3,046 Views)
Thijs, the XY graph that you expected to be attached did not make it. Could you try to post it again?
(3,046 Views)
