Peak search in a Wav file with time-markers
I'm doing a scientific project, so my wizard-skills in LabView are quite limited. I need to open a wav file and find signal peaks in it. The closest I could find is this:
https://forums.ni.com/t5/Example-Code/Count-Peaks-in-a-WAV-File-with-Sound-and-Vibration-Software/ta...
The only problem: I need to get not only Frequency and Value, but also the time, when the peak accrued. Any suggestions, how to add this functionality?
P.S.. I have access to LabView with Signal Processing Toolkit and SignalExpress.
(3,505 Views)
For your problem I think you need to use JTFA. You can read about that here https://www.ni.com/en/shop/labview/joint-time-frequency-analysis--jtfa--overview.html
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,497 Views)
Thanks, Coq Rogue! I added some JTFA functionality for signal visualization. Still, any suggestions about the peak timing measurement?
(3,463 Views)
Alehins,
I found this tutorial that I think will help:
https://www.ni.com/en/support/documentation/supplemental/06/peak-detection-using-labview-and-measure... it deals with measuring peaks
and this example goes through just some basic scalar measurements as a reference
http://zone.ni.com/devzone/cda/epd/p/id/100
Let me know if these work for you. I believe the top link will answer all your questions. Kudos for doing science in LV! 🙂
Sam S
(3,436 Views)
