Peaks and valleys detection of a zig-zag shape waveform
I have 2 waveforms coming in and I would like to detect the peaks and valleys(with the location, or ) and write them to a spreadsheet file.
In a pattern like this
peak #1(waveform 1)            peak #1(waveform 2)                  Location of peak#1(waveform 1)              Location of peak #1(waveform 2)
valley #1(waveform 1)           valley #1(waveform 2)                Location of valley#1(waveform 1)             Locationo of valley#1(waveform 2)
peak #2(waveform 1)            peak #2(waveform 2)                  Location of peak#2(waveform 1)              Location of peak #2(waveform 2)
valley #2(waveform 1)           valley#2(waveform 2)                  Location of valley#2(waveform 1)            Location of valley #2(waveform 2)
  The waveforms come in with varing heights, kind of like a wiggling zig zag shape.  Sometimes the peaks/valleys are very smooth and kind of hard to differentiate from the others.
Thanks.
(3,328 Views)
If you search the forums for peak detect, you will find a number of hits.  Also, here is a recent thread discussin peak detection without setting a pulse width.
Basically, you want to use the peak detection.vi located in Signal Processing > Signal Operation.  That will find your peaks and valleys.
In order to put all of this into Excel/Spreadsheet (do you have / want to use the Excel Toolkit or just the Write to Spreadsheet.vi?), you will need to  feed all of your points into a build array and a shift register and then when you are done aquiring data, feed that into the Write to spreadsheet.vi or to a vi for excel.
The formating will depend on how you feed the data into your array, ie wave 1, location 1 or wave 1 , wave 2, etc
Kenny
Kenny
(3,326 Views)
Does the peak detect vi only detect peaks or valleys or it can do both at the same time?
(3,311 Views)
It can detect both peaks and valleys, but only one at a time.  So you will need one instance for detecting peaks and another for detecting the valleys.
Kenny
Kenny
(3,306 Views)
