Peaks in continuos signal
I have I problem. Maybe someone can tell me, how I can find time interval between two peaks in two continuos signal? In this case HM?catTHM.PNG
(3,571 Views)
(3,563 Views)
I would use Array Max & Min on each of your arrays.  One of the outputs of that function is the index of the max.  Subtract the two indecies and then multiply by the samples rate (assuming both are sampled at the same rate).
(3,560 Views)
Capture.PNGMy real time signals looks like this.
(3,514 Views)
And I need to find interval every time the peaks occurs.
(3,508 Views)
Do I need shift?
(3,479 Views)
Assuming you have fetches of two continous wfrms..
What is your samplerate?
How do you capture the data?
Apply a a peak search on each wfrm part and calculate the difference ?
in your last data picture there are two white peaks .... how to decide which one to take?
Post your code and some real data (in a constant?) .....
Greetings from Germany
Henrik
LV since v3.1
(3,464 Views)
