Pelco SDK
I am working on a project where I need to grab images from a Pelco IP Camera. It's a D5230P Sarix Spectra HD Pendant Dome camera. Using the Pelco SDK I am able to connect to the camera, grab its configuration information, IP address, name, etc. I am unable to get any image data from the camera.
I followed the order of the setup in the C#.NET sample code when writing my LabVIEW code with the .NET libraries from LabVIEW. I used the methods called for in the examples written in C# and as I stated before, I can get basic camera information from the camera so I know I am connected to it.
The problem arises when I attemp to start a created stream and bind this stream to the HWND display method.
I am getting an error 1172 which is pretty cryptic stating that there was an error in executing this node. When I put down a Stream Status method, I get the reading of "stream stopped"....ok, how do you start the stream, I have tried the "goto live" method, the "play forward" method, etc...all getting this same error.
Has anyone else worked with a Pelco camera and used the SDK and LabVIEW .NET libraries to work with it?
Thanks!
Steven Howell
Certified LabVIEW Developer
Systems Developer
Optimation - Houston
steven.howell@optimation.us
(4,460 Views)
I don't see any code.
(4,456 Views)
I havent uploaded any yet. Having some issues with the SDK dll attaching properly for some reason.
Steven Howell
Systems Developer
(4,446 Views)
Also the C# example code.
(4,439 Views)
nyc thanks for your time,
Here is my code, along with the C# example code from the vendor.
FYI the sample code from the vendor did not work on the customers machine either, just showed a black screen. I installed VS2010 Express C#.NET on the machine to test if I could grab images from the vendors example and no joy....didnt work.
Steven Howell
Systems Developer
(4,423 Views)
good afternoon nyc,
Have you  had a chance to review the code I posted?
Steven Howell
Systems Developer
(4,353 Views)
Sorry about that.
For some reason I did not see your reply post.
I will take a look now.
Edit:
I would be a little concerned that the C# code is not working.
I also have VS 2010 C# Express, and the code was fine except that it was complaining about not having Pelco which is to be expected.
I would ask for their help to get that working; it is their code.
In your Get Panel Reference.vi. you are closing the reference immediately.
What happens if you wait to do that when your program closes?
I usually close references during the shutdown/cleanup step.
Edit #2:
In the C# program, try changing the project's Target Framework to .NET Framework 4 instead of .NET Framework 4 Client Profile.
(4,348 Views)
