Perdida de archivo .lvproj
Buenos días. Estimados, reciban un cordial saludos.
Esta es mi primera pregunta en la comunidad de NI.
Voy a ir al grano, perdi una carpeta donde tenia un programa para una sbRIO 9612, es decir, perdi todos los archivos relacionados al programa (.lvproj, extensiones, subviws y demas).
Pero, tengo la sbRIO con el programa cargado, corriendo y funcionando.
Existe alguna manera de rehacer ese codigo?
Mil Gracias por su ayuda.
(2,431 Views)
Dear Yhoan,
I'm sorry, that sounds like a very unfortunate situation... 😞 I am not familiar with sbRIO, but I am guessing that LabVIEW compiles the code before sending it to the device, so the source code is probably not there, similar to when you build an executable. This would mean that there would be no way to get the source code back, unless your IT department has backed up your files. Hopefully someone with experience can weigh in soon.
Either way, I recommend setting up source code control immediately, and use it for any piece of code that you spend more than ~30 minutes on. Here is a good article from Delacor explaining how to get started.
(2,427 Views)
