Perform DFT in LabVIEW
Hi , I would like to compute  DFT of a signal. Windowing should also be implemented  to clean leakage from the spectrum. If sample rate is also specified, a frequency vector should be returned. Otherwise, returned frequency vector should be empty.
 I should also be able to return the magnitude of the tone of interest ( specific frequency)
Could you please let me know if I can do it in labVIEW or if there is a block for that?
(4,461 Views)
Read the Detailed Help for FFT:
FFT Details
1D FFT
For 1D signals, the FFT VI computes the discrete Fourier transform (DFT) of the input sequence with a fast Fourier transform algorithm.
Will this do what you wnat?
Lynn
(4,458 Views)
