Perform a single task if comparing 2d arrays do not match
Hi All
Unfortunately I cannot post my VI but hopefully I can explain my problem well enough. I have a program where I poll for data every 10 seconds from my UUT. Currently I have the data(strings) being output into a 2D array. Since the array is very large, I basically want to set up my code to compare the current captured 2D array with the 2D array I captured 10 seconds ago (I am using a shift register in my loop) and save the current entire 2D array to a file only if any of the elements have changed (Specifically I will save the initial array, then continue to save each array that is different than the previous). I am not sure how to best compare the arrays. When I use the "not equal?" function, the output becomes an array of boolean True/False, and I dont know how to use a boolean array to control a case structure with my file save code. Is there something I am overlooking or a way to do this more efficiently?
Thanks!
(3,647 Views)
Accepted by topic author davidthealias
Right click on the equals function, point to comparison mode, and choose "compare aggregates".  This should output a single true / false value.
(3,624 Views)
Wow that was easy. Thanks!
(3,619 Views)
No problem.
(3,615 Views)
