Perform action after time delay
I would like to know after as user specified amount of time (relative time) perform an action eg set the case structure to true
I have not lost my mind, it's backed up on a disk somewhere
(4,381 Views)
Check the time specified is reached whithin a while loop. Connect the output of the comparison to the case structure.
(4,366 Views)
H PauldePaor,
There are various ways to implement this functionality in LabVIEW.  Could you elaborate on the specific application?
This KB might help: http://digital.ni.com/public.nsf/allkb/05A9C3B0A4D5A7638625712B006FB30F
(4,364 Views)
You can use the wait untill the next ms function(with  a control input) or create a dedicated bit to trigger a set of events.
Your question is not very clear. Can you be more specific
(4,359 Views)
Hi nickf,
I used the elapsed time VI with a user input for the time delay and wired the time has elapsed to the case structure. This worked for me
(4,352 Views)
great Smiley Happy
(4,343 Views)
