Performance of LVclass "Children in memory" node
I'm making an application that uses what is pretty much a factory pattern.  Rather than predefine all possible objects in multiple places, I want to programatically get a list of all descendants of a particular object, and then be able to choose from them on the fly.
LabVIEW helpfully comes pre-loaded with the Children In Memory[] Property for the LVClassLibrary reference.  However, when I tried using it, it ends up being pretty slow. (~230 ms to make a list of 9 classes).
I've created a workaround that seems to be about 5x faster (~40 ms on the same list) but it's also a bit of a hack in that it just parses the "All VIs in memory" node to find all currently loaded classes, and then checks to see if it can be cast to the parent class.
Neither of these options feel like they're the "best" option.  I could probably speed up the parsing on the "All VIs in memory" results some, but it doesn't feel like it ought to be the quickest method.  For compiled applications I can add in a cache check to avoid running the same check twice, but for live code I want to be able to load in classes dynamically.
Screenshots for a quick peek:
Those were both with the same 10 classes in memory, all with a common ancestor, and about 30 VIs in memory.  I also tried it with the full application loaded in memory, which raised that to 3400 VIs and 96 classes in memory, and the run times increased to 60-70 ms for the "All VIs search" method and changed to 250-300 ms for the ChildrenInMemory[] node method, so neither has a particularly bad scaling issue.
Does anyone have a method either more "proper", faster, or (hopefully) both?
This is all in LV 2018 SP1 32-bit with the f3 patch applied.
The sample code is attached.  It was originally a proof of concept LVOOP project that I picked to re-use because each class only has 1 or zero methods, and the classes involved were all descendants of a common "Animal" ancestor (cats, birds, etc.).
Message 1 of 12
(7,098 Views)
Have you benchmarked the "Get All Descendents" invoke node on the parent class? It sounds more like the function you are looking for....
EDIT: Ah, i see. The Get All Descendents doesn't list the child classes, but their items (methods, controls). So it obviously doesn't work out for you.
So another consideration: Did you try recursive VI search rather than looping?
Norbert
Expert: Geometry
Message 2 of 12
(7,065 Views)
If I switch the NI implementation to paralellize the loop, it drops from ~240 ms down to ~200 ms.  Due to the rather simple nature of what I'm doing I think that would be the same if not better than it would be to set up a bunch of recursive VI calls.  So a slight improvement, but not much.
Even if the delay from the "Get All Descendents" was completely eliminated, the delay that comes from the "LVClass.Open" method is longer than the other method.  Just opening the class reference seems to take a minimum of 50 ms.
Message 3 of 12
(7,050 Views)
As an additional note, if I change this example to actually include all the classes I actually may use in my project (10 direct descendants, with those descendants having 0 to 3 descendants each, and occasionally a single sub-descendant after that, for a total of 43) then the time for the "LabVIEW node" version goes up to over 2000 ms (even with full parallelism enabled), while the time for the "All VIs in memory" workaround remains at ~50 ms.
Message 4 of 12
(7,047 Views)
I usually make my factories a bit different...
Simply try create a new default class with a given name (e.g. from an ini file). Then cast to the parent. It this works, I have my fabricated classobject, if not, the name wasn't valid...
Then make sure all children are in memory when building an executable. I use a pre-build script to add those classes (class constants) in a blank VI, and then put that VI in my code, or add it the the top level VIs in the build (always include doesn't work IIRC). This is done pretty much like your code, that is slow. During compilation, the speed will not be a problem though.
Message 5 of 12
(7,032 Views)
I guess this is when you create descendant you also add it to a list or named queue so you have easy access to them.
Part of G#'s garbage collection is to do such a thing, so there is always named queues with all instances of specific objects. Maybe that is a solution?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 12
(7,024 Views)
It's the enumeration of available children that is slow.
I don't think the creation is that slow, although it might help a bit...
Message 7 of 12
(7,019 Views)
Note that you'd need to do something similar no matter how your factory works. Unless you put the child constants in the factory. But if that's acceptable, you might as well refactor the factory completely (put the children in an array and use a for loop to get their names)… There will be a moment that you forget to add the child, and send it to the customer without it.
Message 8 of 12
(7,015 Views)
Accepted by topic author Kyle97330
One improvement on the "AllVIs" implementation is "Application.All Libraries in Application Instance" node, which saves time & effort on string parsing. In my application I saw the execution time drop quite a lot on the first run of an application (~1500ms to ~50ms) by avoiding the poorly performing "Open LVClass Reference" and "Get all Children" nodes.
Message 9 of 12
(5,880 Views)
Hm, I'm trying to figure out why I wouldn't have seen that when I posted this 2.5 years ago.
All I can think is that I was focused on the keyword "class" and I didn't think to look around for the "library" key word as much as I should have, but I posted this quite a long time ago so I don't remember what I was thinking specifically.
I'll have a look at that and try it out in my code and if it works (I see no reason why it wouldn't...) then I will return and give this a very belated "Marked as solution".
Message 10 of 12
(5,847 Views)
