Performances Counters
Bonjour, on me conseille d'utiliser un compteur de performance pour détecter lorsque mon application Labview plante et ainsi la rédémarer automatiquement ! Y a t'il une possibilité de réaliser cette opération ou existe t'il un autre moyen de détection ? Merci pour votre aide
Hi, I want to use a Performances Counters to detect if my VI is down and to restart it automatically! Is it possible and how can I make that ? Thank you for your help.
(3,385 Views)
A VI will only be down when loaded dynamically and started with the "Run VI" method.
You can keep the reference to the VI and check the VI with the property "Execution.State" regularily.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,370 Views)
OK, thank's. Where can I find the "Execution.State"?
(3,361 Views)
You can have a look on the following kb
Is There a Way to Programmatically Tell If a VI or SubVI Is Running?
Have a nice day,
Nicolas
(3,342 Views)
