Performing OCR on Revolved Text using NI vision assistant
Hello Everyone,
I am currently working on a vision project where I have to read a serial number on a part using OCR. I am using NI Vision Assistant to build the code and then I am exporting the script as a VI. Originally I had been reading serial numbers that were straight and I had a rectangle placed around the serial number so that it was easier to pattern match too (it was a bit overkill, but I'd rather be safe than sorry). Well, to keep a long story short, the location of the serial wasn't correct so the script needs to be changed. The serial number will now be revolved rather than straight.
I am still using pattern matching to locate the serial number, and than setting a coordinate based on the matched pattern. Those both work great, but when it comes to detecting the correct serial number, it struggles with the revolution. I am using a test image built in word to locate the serial number, I am hoping to build up from there to full time production parts. I've attached images of my settings as well as the program running OCR on the serial number. I can add my script if someone wants to look at it and mess around with the settings.
Dan
(3,903 Views)
Accepted by topic author drogers13
Have you tried checking the Auto Detect Multiline and Rotation in the Read options?
Also isn't there a vi in VA to unwrap circular text? If so you may want to try that before reading and decoding.
I have done some OCR in VA/LV but nothing with curved test.
-AK2DM
(3,881 Views)
Hey AK2DM,
I tried to use the Auto Detect Multiline and Rotation in the read options and it just changed the AB to an M instead. I haven't seen a VI to unwarp circular text, but there is a lot of stuff within VA. I will see if I can find something like buried within VA and post my results.
Dan
(3,864 Views)
See LabVIEW\examples\Vision\Image Management\Unwrap Barcode.vi
Not sure if it's accessible from VA.
You can also manually create a circular strip ROI and convert it to annulus:
(3,832 Views)
RamonG,
Thanks for the response. I was able to find a solution using NI Vision Assistant. I will most likely have to do some tweaking to get into working just right, but there is a annulus searching tool.
Thank you all for your help!
Dan
(3,819 Views)
Awesome.
RamonG- yes, that was the vi I had in mind, mistakenly thought it was in VA.
-AK2DM
(3,811 Views)
