Performing and External Calibration of a PXI7831 using LabVIEW
Good Morning All,
    Have any of you any experience with performing an external calibration on a PXI783x series FPGA board. There is an NI-RIO LabVIEW utility to do a self calibration, but we will need to figure a means of do a calibration to an external NIST traceable standard.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,616 Views)
The only way, at this time, to get external calibration is by sending the board to National Instruments. Unlike Data Acquisition boards there is no way for users to externally calibrate. If you would like to set that up, call in to support and we can begin that process.
Rick Kuhlman
NI applications Engineer
(2,605 Views)
Thanks for responding. We are just developing the calibration methodology for a test system we are building, not ready to calibrate the PXI7831 or any of the others at this time.
P.M.
Putnam
LabVIEW Champion
(2,602 Views)
