Periodically cycle through tab controls
You also want to place the "Pages" property node and "array size" before the loop. Executing it once is enough!
Message 11 of 34
(3,137 Views)
I used the tab.vi that was given and I'm getting an error. It says "The case structure must have a Boolean, numeric or enumerated input wired to its selector terminal (the '?'). I wasn't getting this error until I tried out the new block of code suggested by apok. Also, altenbach, what do you mean by "before the loop"? Should that entire line be placed outside of the while loop? If so, how should it be wired back into the Quotient & Remainder? Thanks again, guys.
Message 12 of 34
(3,112 Views)
the image was to be used as a suggested example that needs to be modified for your use...
suggest that you not use case structures as the code will only update every multiple of 30 seconds. continously monitor your bools and plug them into the "select" functions when you've reached your limits. now this is a suggestion and not a solution, as we cannot see the rest of the code in the other cases and therefore assume (makes me look like an @ss, because I cannot read minds yet?). also, the input constants need to be change to what page you want to show or again to your specific needs here....  Smiley Wink
Message 13 of 34
(3,093 Views)
I'd expect to see "Torus 1" in red.  Did you copy that structure from somewhere where it was selecting on an Enum?  It also looks like the blue wire is going into a tunnel behind the selector terminal.  That's probably your problem.
Jim
Message 14 of 34
(3,089 Views)
Yes, I just copied and pasted the entire case structure from my first block diagram before adding in the while loop. Sorry if I'm not very good with LabVIEW. This is for an internship that I'm working at right now and I'm having to do this on LabVIEW with zero previous experience. I've learned everything I could in the last two weeks or so, but I really appreciate all of your help. As far as not being able to see my other cases, they're all identical except they deal with different Torus machines. This will not be my final code because in my final code the numeric controls labeled "mid temp" and "exit temp" will actually be read from a thermocouple. I am just creating this for now to try to find a way to have the four different Torus machines temperatures be continuously graphed and have an alarm go off any time that any of the four machines gets too hot or too cold. I also want the front panel to cycle through the four graphs periodically. I'm not 100% sure if using a case structure with tab controls is the best way to do this, but it's the only way that made sense to me at first.
Message 15 of 34
(3,084 Views)
Was your original program working as you wanted it to, except you simply wanted the tabs to cycle?  If so, juat make the tab.vi a parallel loop and leave the original program untouched.
Could you post your original VI, rather than images?  We'll be better able to see where you're going and how we can help.
Jim
Message 16 of 34
(3,070 Views)
@jmejiagusmer wrote:
Hi guys so I have a VI where I have 4 different tabs in a tab control where each one of them is monitoring a different machine's temperature. I would like to know if there is any way to automatically have labview cycle through the tabs at maybe 30 second intervals while the VI is running. I have the temperature monitors hooked up to some boolean indicators to let me know when one machine is too hot or too cold, so it would be nice to be able to have labview automatically switch to that tab when any of the boolean indicators go off as well. I'm very new to labview so maybe this is a very simple fix that I just don't know about. Thanks in advance for any help!
hopefully.........gl!  Smiley Wink
Message 17 of 34
(3,059 Views)
oooops....the "greater than zero" must be change to "greater than equal zero"    Smiley Wink
Message 18 of 34
(3,047 Views)
You could avoid that all together by using the Compound Arithmetic Node set to OR instead of the Build Array.  Then you don't have to do the search either.
Message 19 of 34
(3,043 Views)
Well, it was working in the sense that I could select the different tabs and it would record the data points onto the graph every 30 seconds. My booleans were lighting up as expected, as well. However, I realized that when I was on tab 1, the tab 2 data points would not record on the graph and vice versa. Ididn't have the tabs cycling, either. Here is my original VI.
Message 20 of 34
(3,038 Views)
