Phantom Line On PDA App
I have a PDA application that looks fine on the PC, but when I run it on a PDA a phantom line appears across the top of the screen.
Can anybody tell me where this is coming from! It has only just appeared, I have been working with this application for some time.
The main screen is made up of an oversized tab control.
I have attached images of the PC & PDA screen shots.
Thanks in advance
ssk
Message Edited by ssk on 07-25-2008 09:23 AM
(3,270 Views)
I may know what is going on, but it will take a little explaining.  When I started reading your post, I said to myself "I wonder if he/she is using a tab control?".  Almost before the thought ended, I read that you were using a tab control.
I wrote a PDA application with a non-oversized tab control with multiple tabs.  As I kept adding functionality, I kept adding tabs.  Eventually, I added a tab, and the line showed up.  At the time, though, I didn't realize the cause.  I even showed the application to a integrator who worked on PDA stuff, and he could not explain it.  As it turned out, if I shrunk the font size of my tab text, the line went away.  Now even when the "problem" tab was added, it did not extend beyond the right boundary of the tab control on the PDA, PDA emulator, or PC version, so I think it is a bug of some sort.  I needed to leave about 15% of the entire width of the tab control free, so that the the left side of the first tab to the right side of the last tab was no more than 85% of the tab control width.
I suspect you are having the same sort of buggy issue with your tab control.  I have no proof, but just a strong gut feeling based on my experiences.  Do you have titles on your tabs?  if so, try shrinking the font.  If not, maybe you need to have titles on your tabs.  Who knows?  Hopefully someone from NI will respond with a real solution.
Lots of luck,
Ed DeWitt
(3,248 Views)
Thanks for the pointer Ed,
I have just reduced the tab label's text size and the line has disappeared!
ssk
(3,228 Views)
Thats great!  I'm glad it worked.
I still would be interested to know if anyone from NI knows about this issue and if there is a current or forthcoming resolution.  I had the problem using a Dell Axim X51v, but I am sure it probably happens with different PDA's as well.  What type of PDA are you using?
(3,211 Views)
It appeared on a Dell Axim (wm5), ipaq hx2750 (ppc 2003) and an ipaq 614c (wm6 smartphone).
Just another pda bug!
(3,209 Views)
