Phantom NI 6008
Strange new work setup.
When I log into the T Series Thinkpad running Win7x64 NI device monitor detects a non-existant NI USB 6008 and offers me a blank screen of choices of what to do with it (None of the usual selections like Configure in MAX, Signal express, LabVIEW etc..the selection area is BLANK)
Something tickles the back of my mind that this has been seen before but My Google skills must be a bit rusty.  Any ideas anyone?
(3,029 Views)
LMGTFM
http://forums.ni.com/t5/Multifunction-DAQ/NI-USB-6008-detected-when-one-not-present/td-p/437676
Unfortunately there is no work around in the thread.So,  was there one ever found?
(3,023 Views)
Hi Jeff,
Out of curiosity, what version of NI-DAQmx do you have installed?
There were a few versions of NI-DAQmx that had a bug that would cause non-NI HID devices to be enumerated as NI hardware if the PID matched a valid NI PID.  Here's a KB on the issue: Why Do Certain USB Interface Devices Prevent NI Devices from Appearing in MAX?
That seems the most likely cause of this issue.
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
(3,000 Views)
Latest and greatest everything.  off the Feb 2014 Media with all updates.
I'm sure its something odd on the Thinkpad.  and its not super annoying but I was hoping more was known
(2,991 Views)
I'd be curious to see the MAX report to see some information on the 6009.  We might be able to figure out where it's coming from.
Seth B.
(2,959 Views)
As you wish Seth
I think the relevant event log entry is attached too.
(2,948 Views)
