PharLap
Hello!
I have an real time application using CompactRIO. I created an stand alone application and an VI in my Host Computer (called prosys.vi) that give orders to stand alone application to start up. All are working perfectly, but I get an error when I close the associated project (and stand alone application continues still running) and I try to run prosys.vi again. In other words, if I close prosys.vi but I don´t close the project, and after I run prosys.vi again, everything goes well; but if I close prosys.vi and the project, and after I open the project and run prosys.vi again, I get a error that closes the project in my host (but stand alone application continues still running) and don´t let me connect to CompactRIO application. The RT target error shows:
#OSName: PharLap
#OSVers: 12.0
#AppName: PH_EXEC
#Version: 8.0
#AppKind: AppLib
LVRT.DLL reference address: 0x002FFAAC
Can you help me?
Thank you!!!!!!!!!!!!!!!!!!!!!!!
Marco Santos
(3,180 Views)
Hi Santos,
May you send me your project then I will try to repeat the error you can see and will be in a better position to help you.
Regards
Message Edité par Jérémy Marliot le 03-18-2008 12:51 PM
Jérémy M. | LinkedIn - Contact
Don't forget to give Kudos to good answers.
(3,139 Views)
