Phase Response
Hi, I've set up a program which inputs a sinusoid to hardware via labview and a daq, and retrieve its frequency response via a position sensor to the DAQ. I can receive the amplitude of response, however, I'm not sure how to find the phase of it (so i can see the phase lag between input and output).
I would appreciate it if someone could help me with this.
Much thanks
Viksen
(3,427 Views)
Hi
Could you describe your setup a bit more. Which version of LabVIEW and drivers are you using? From the top of my head I think you might be able to use Extract Single Tone Information.vi, this allows a signal to be input and it gives the information on amplitude, frequency and phase of the signal. The function can be found at Signal Processing >> Waveform Measurement.
Let me know more information and I will be able to help you more
Kindest Regards
YatinM
Message Edited by YatinM on 05-25-2007 04:13 AM
Message Edited by YatinM on 05-25-2007 04:15 AM
(3,375 Views)
Viksen,
From trigonometry the product of two sine waves of the same frequency has a zero frequency component proportional to the cosine of the phase angle difference and a second harmonic component. Multiply the input and output together. Filter the product (or use AC/DC Estimator) to get DC component. Scale appropriately. Result is cosine of phase shift.
Lynn
(3,356 Views)
You could use cross power spectrum  on the two signals, find the index of maxium magnitude (array min & max) use that index to find the right phase (index array). You can multiply the the index by df to get the frequency it detected.
(3,343 Views)
