Phase Shift and Power Spectrum..
Power is proportional to the square of the voltage, so the FFT plots will reflect this.
Randall Pursley
Message 11 of 25
(2,943 Views)
Usually the two terms are used interchangeably.  To get real technical, power is measured in either watts (linear scale) or dB (log scale).  Amplitude can be expressed in volts or dBV.  But generally, power and amplitude mean the same when it comes to transmitted signals.  Pay attention to the units of measurement instead.  There are probably mixed opinions on the use of power vs amplitude.
- tbob
Inventor of the WORM Global
Message 12 of 25
(2,943 Views)
Hi..
I am now actually implememnting a instrument in which i need to get the signal at DC.. So I saw another implememntation in which one has used a filter (chebyshev, inv. chebyshev etc..) to filtewr out the signals beyond 0.75 Hz and then he has taken the rolling average of all the remaining values.. Instead of that can I take the Amplitude Spectrum of the resulting signal and then take the value at DC using the extract portion VI in LabVIEW.. And if I do tht I need not multiply by sqrt (2) right.. Or should I multiply??
Thank U.
Gokul..
Message 13 of 25
(2,935 Views)
Hi.. Someone out there.. please help me out.. please reply to the above question...
Thnx..
Gokul.
Message 14 of 25
(2,927 Views)
hey gokul
you follow that filtering and rolling average method. that will be efficient.
Anil
Message 15 of 25
(2,924 Views)
anil.. thnx a lot.. but can u explain me y the other method is not efficient..??
Message 16 of 25
(2,919 Views)
plz... help me.. answer to the above question..
Message 17 of 25
(2,902 Views)
Hi.. When i used a low pass filter I am getting results only when the low pass freq is below 0.5 Hz.. Above tht I am not getting any answer.. why is it so..?
Message Edited by gokul_bits on 06-22-2006 04:31 AM
Message 18 of 25
(2,900 Views)
You do not have the sampling frequency input wired so it defaults to 1 Hz.  Due to Nyquist limitations, the highest frequency you can filter is a little less than 0.5 Hz.
Randall Pursley
Message 19 of 25
(2,894 Views)
Hi Gokul
yesterday this site was giving some problem here, so i could not reply to you...
Just check out "Extract portion of the signal", there you can not mention frequency. you can mention the no.of samples or time period. So it is better to go with filter which remove the signal above 0.75Hz to get DC signal........
But i have one doubt over here.......Where from this signal is coming. i mean are you getting this from outside or you are simulating it in the software...To get DC signal you can use Express VI also i think........Just let me know what exactly you are doing...so that i can give some sort of solution to you.
Regards
Anil
Message 20 of 25
(2,885 Views)
