10-20-2008 10:18 PM
We are reading two voltage signals, and need to measure the phase difference between the two, as well as the magnitude (both continuously). (ultimate goal is to measure the impedance of the system) The system seems to crash everytime we write to file. Any suggestions for what might be causing this, or how it might be fixed?
10-20-2008 11:40 PM
What is the message you receive when it crashes? Is it an out of memory message?
10-21-2008 07:45 AM
Thanks for the post!
I agree - we need more details of the error (screenshot) and also would it be possible to see the code?
In the meantime I would recommend looking at the write to file example vi's (Help>>Find Examples). Does this generate the same error?
Kind Regards,
10-21-2008 11:46 AM
Hi!
If you could post up a screenshot of the error then we can take it from there. This is not expected behavior and I searched but didn't find any other instances of this happening. Thanks!!
10-23-2008 11:31 AM
georgetta-
I was wondering if you still needed help or if you found a work around? Thanks!!
