Physical Channels not found
I am using Labview Full Development Suite 2009 on a SUSE linux Version 12.1.
I am tyring to read in an analog signal via a PCI card through an SCB-100 box,
but I am not able to find the physical channel
in the I/O dropdown controller of my vi.
In the NI-DAQmx Base Task  configuration utility I created a new task to see
the Device : NI 6031E: "Dev1" (PXi5::0::INSTR). And in the channel list
I see three channels - 0, 1,  and 2.
I am attaching:
i) Screen shot of the backend of the simple vi I used,
ii) Screen shot of the front end with the error message ( code 200428)
iii) Screen shot of the NI Base Task Window
Is there any driver I might have to install to fix the physical channels in the I/O of my vi?
Thanks much for you help.
Please let me know if this information is insufficient for trouble shooting.
Best,
-CE
(2,742 Views)
Did you try to increment the array index?
(2,723 Views)
Where exactly did you wire that Physical Channels control to.  To error seems to insinuate that you wired it to the Task input, not the Physical Channel input.
(2,711 Views)
