Physical channels not showing up in ULx Create Channel
I am trying to create a digital out channel with the following resources:
- MMC USB-201 DAQ
- ULx Library
- LabVEW 2022 Q3
The Create Channel VI is wired to a constant, but no physical channels show up in the drop down list. My DAQ is connected to the computer, and InstaCal can see it. I tested the ports and they passed. I used this same setup yesterday and it worked fine.
I tried unplugging and plugging everything back in and adjusting the I/O Name Filtering options. I'm wondering if there are any other suggestions to try.
(909 Views)
IF the list is empty, it's probably because labview does not see the channels on the device.
try reinstall the ULx drivers
(891 Views)
