Pi Approximation
I just saw a funny meme about a fraction that approximated PI to 2600 digits. That got me thinking of trying to find some, and this was my result!
22/7 (the real PI day) is surprisingly good at such a simple fraction. 355/113 is a really good approximation and you need to get to 99733/31746 to get the best 5 digit one. With the last one it's correct to 10 digits!
Qestit Systems
Certified-LabVIEW-Developer
Message 1 of 30
(2,229 Views)
What we really need is a TAU day...
More PI for everyone!
Message 2 of 30
(2,218 Views)
Cool!
Hey, this is 2026, so why not use a map instead of variant attributes?
On a side note, you could gain about 10-20% by just replacing the format into decimal string with a typecast. 😄
One flaw is that the third and fourth item have the same ratio
Message 3 of 30
(2,187 Views)
Here's a quick draft that is about 50x faster. but leaves out digit groups that show no improvement. Probably has some bugs. 😄
Message 4 of 30
(2,154 Views)
IMHO, when slicing up pi it is important to determine if there really are any bugs.  Just guessing that they exist and serving them up anyway is making my laugh my a** off!
EDIT: I was just informed that my reaction is irrational.
Message 5 of 30
(2,130 Views)
You are a COMPEX individual. 😄
My main concern were actually inherited from the original code. For example I did not understand where the 3183000 constant comes from. I initially made one with a while loop that terminated after checking all numbers up to a certain number of digits. This was slower, but still 10x faster than the original.
Message 6 of 30
(2,108 Views)
Not really 😕  Whenever I see numbers that are imaginary I tend to grab an oar and rho in any direction. (Which brings the thread back 2pi)
<rimshot>
Message 7 of 30
(2,097 Views)
Keeping it real. 😄
Message 8 of 30
(2,080 Views)
Paradoxically, using complex realm can simplify the math.  In AC circuit analysis, if you stay in the domain of real numbers, you need trigonometry; however if you venture into the domain of complex numbers, you only need linear algebra.
Message 9 of 30
(2,055 Views)
If you stay in Cartesian coordinates.   The linear algeba rolls up to simple vector addition when using Polar coordinates.
Message 10 of 30
(2,045 Views)
