Picaxe to LabVIEW
I am using the "Basic Serial Write and Read.vi" example in LabVIEW 8.6. I can send information from the PICAXE 08M micro to LabVIEW via the serial cable. However I want to store the information somewhere to be manipulated at a later time.
The LabVIEW example deletes the information after a few seconds. How do I store stuff?
Cheers
Message 1 of 9
(6,424 Views)
What information is this that you want to "store"? Are we talking numbers? Have you looked at the File I/O functions?
Message 2 of 9
(6,410 Views)
I'm sending a "string". I've solved the problem by looking at the advanced example in the LabView files. Using the "decimal string to number" function I was able to take the data that I needed and do my calculations.
Thank you for the interest.
K
Message 3 of 9
(6,403 Views)
OK, so I got serial read and write to work, but not together. I am sending ASCII "GO" to the PICAXE chip. After some calculations on the PICAXE chip I want the information to be read.
The Problem:
Both read and write work, but not at the same time. It seems that I can Write "GO" but as soon as I click the READ button the Write function stops working and no information is Read.
Any ideas?
Cheers
K
Message 4 of 9
(6,374 Views)
Are you still using the "Basic Serial Write and Read" example? I ask because that example doesn't have a "Read" button. There's a toggle switch that you can set to True so that when you run the VI it will perform a read after it does the write. If you're not using that example, then please post the VI that you're using.
Message 5 of 9
(6,364 Views)
I realise now, that the PICAXE 08M does not support duplex serial communication. For that reason I have made this code which Writes something, then resets the current COMPORT so that the READ function can be used.
here is my code.
If you see any improvements let me know. Thanks.
Message 6 of 9
(6,311 Views)
I have no idea what this has to do with anything. Full duplex is when you have separate pins for transmit/receive. Half-duplex is when you have the same pin for transmit/receive.
As for your code: I don't understand why you have inner loops for the write and read. Are you trying to continuously send out the command if you get an error? Why? What makes you think you won't have a serial port error again in the next iteration?
Message 7 of 9
(6,304 Views)
Kamilan, Please don't start new threads with the same question.
The thread has now moved to here.
Message 8 of 9
(6,300 Views)
Hello, I was just following the example. Thank you for pointing that out. I have removed the while loops. The code runs alot better now.
Here it is.
Message 9 of 9
(6,297 Views)
