Pick out empty strings from an array
Cyril and Gerd!
We are very new on LabVIEW so we think that was an unnecessary comments before from Cyril :-(... and we don´t understand what Gerd meant with the suggestion that we should change the tunnel to a shiftregister. We now have tunnel with indexing enable. Should one drag that to a build array after the while-loop or in the while-loop?
Message 11 of 18
(1,639 Views)
Hello Ex-Jobb,
here you got an example of our previous advices...
Message 12 of 18
(1,572 Views)
Hello Ex-Jobb,
btw. why do think I'm from Sweden?
Message 13 of 18
(1,571 Views)
Hello!
Oh so THAT is how you meant 🙂 We did not get how to do with the build array-vi before. We thougt that one just could drag the array in to it! We are so greatful and could not be more happier 🙂 It was just a chance because your nick looks like a Swedish name. Once again, thank you!
Message 14 of 18
(1,569 Views)
Hello Ex-jobb,
you had your chance, but you missed 🙂
Message 15 of 18
(1,568 Views)
Maybe from Germany then? *smile*
Now we have to ask another simple (for you) question. How to initiate an string-array to the shiftregister?? We tried here and we comes as far as to the array-constant but we don´t get how to initiate and that it is a stringarray :-(. Thanks again 🙂
Message 16 of 18
(1,565 Views)
Hello Ex-jobb,
2 fast answers:
1) as I did in my example: place an empty string in an array constant
2) use "initialize array"-function and wire a string constant and a number to it (number can be zero)
Message 17 of 18
(1,561 Views)
Hello!
Yes we tried to do as you did in your example but it did not work before. But now when we read your explanation it works 🙂 Thanks a lot for your help 🙂 We might come back
Message 18 of 18
(1,557 Views)
