Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2
Pick out words from a string with tabs?
Re: Pick out words from a string with tabs?
NeilR
Active Participant
02-22-2005
09:09 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
As I indicated earlier, you need to remove the code associated with Method 2, including the "Build Array" and the "Scan from String". Just wire the string array element into the while loop, then it should be fine.
0
Kudos
Message
11
of 11
(290 Views)
Reply
2
All Forum Topics
Previous Topic
Next Topic
