Pickering Driver Installation Issue
I was trying to install Pickering driver in my RT Linux. And when I was connected the host with RT & tried deploying, I am facing below mentioned error. I couldn't find any library that to be put in RT. Where I need to put this lib?
(2,833 Views)
Hope this supports
https://www.pickeringtest.com/en-in/kb/software-topics/using-pickering-switches-in-various-programmi...
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,777 Views)
I have tried the same procedure they have mentioned ion that page. But couldn't get the proper expected output.
(2,763 Views)
We have similar requirements and it works fine for us. Not sure on the specific issue.
(2,752 Views)
Do you have the proper document of procedure for "Pickering driver installation in RT Linux" .
(2,745 Views)
