Picture animation
HI, everybody
I have a flame on my front panel and I want to animate it or just see it moving when I run my VI. Is it possible ??? And If it is, can I have an exemple please !!!!
Message 1 of 9
(4,329 Views)
You can use a gif picture and you don't need to do anything.
Or use a picture ring
Message 2 of 9
(4,326 Views)
The easiest way is to use an animated GIF image. All you need to do is drag it into your front panel. You should easily find one by searching Google for "flame GIF". You can also create them yourself using some freeware tools.
___________________
Try to take over the world!
Message 3 of 9
(4,325 Views)
Hi Pnt,
Thanks for your help but Can I have the animation just whene the VI is  runing ????
Message 4 of 9
(4,314 Views)
The next easiest approach is to use a picture ring and continually cycle through is images.
The code I attached in this thread has a sub-VI that grabs the images in gif's. Read my notes on operating it and watch what happens when you import a new emoticon.
Take those images and import them into a picture ring.
Have fun,
Ben
Message 5 of 9
(4,290 Views)
And ben is there any way to add tiff image in the front panel?
Message 6 of 9
(4,287 Views)
I have done it for a flash file.Use the  invoke node stop and start.Should solve ur problem
Message 7 of 9
(4,264 Views)
This has already been asked.
Message 8 of 9
(4,257 Views)
You can also control a GIF by placing it in a tab control or a customized boolean and then showing or hiding that control.
___________________
Message 9 of 9
(4,228 Views)
