Picture shift
I need to import one jpg image to a picture and then shift it left/right and up/down inside the picture in order to free space to allocate a second picture. This should be done dynamically. Is there an easy way to do it?
Pier
(3,265 Views)
Adjust the image rectangle to the position where you want it rendered. Example attached (LV 7.0).
Good luck.
(3,261 Views)
Grr! Attach I say!
(3,263 Views)
Thank you.
I am now trying to solve the following problem (see attached vi): 2 simple bmp pictures are generated, then I want to plot first one jpg image (say bckgnd.jpg) and place above the 2 previous generated bmp pictures WITHOUT their (white) background.
Pier
(3,177 Views)
