Pipeline leak in VI
Im a college student with a study of "Design of a water distribution system with leak detection using LabVIEW". Is there any toolkit that can apply leak on pipelines in VIs? We will not have a prototype so is there any toolkit that can visualize the leak for simulation? Thanks
Message 1 of 13
(4,051 Views)
I'm thinking flow - flow * random number ought to simulate a leak between ultra slow drip and open pipe.
There is always a leak.  You usually can't detect the single molecules transpiring through the pipe wall.  Define a threshold for "Leak that warrants repair."
Message 2 of 13
(4,024 Views)
I can tell you are not a BME major -- they sometimes study "fluid distribution systems" (heart and blood vessels" and usually make analogies with what they learned in Electronics 101, something about Kirckhoff and his Laws (or InLaws, maybe).  If you were trying to deliver electrons to a load (say, a motor or a light bulb), what would constitute a "leak"?  [I've heard that a Very Big Leak is called a Short Circuit ...].  Simulate the "leak" by having a thin, tiny pipe that lets the fluid leak out onto the ... hmm, what do you call it?  Oh, the Ground ...
Bob Schor
Message 3 of 13
(4,005 Views)
Bob Schor
Did you see the Breakpoint thead of Ben's where I equated Ohms Law etc..  for hydraulic systems?
Bonus kudos for a link ( yeah, I finally got  media and am heading towards your neck of the woods so, the 8-Ball laptop is off doing other stuff and cannot be  bothered with writing code.
Message 4 of 13
(4,004 Views)
What i mean is a visual leak on the pipes. We will need a tool kit that can put a leak on the pipe, itself for simulation. We need to put holes on the pipes
Message 5 of 13
(3,960 Views)
A drill and some drill bits can put a leak in a pipe.
Message 6 of 13
(3,950 Views)
So. A random number would What do you mean by visual?  A custom control with hundreds of pix as jpeg might work...does the user experience expect a visual indication of water dripping?
Trust me, I have washed dishes in LabVIEW .  Also, dug dirt.
Dirt at 130 tons per minute.  Dishes at a few hundred trays per hour ...
You don't need a toolkit I think you need a vi.  What have you written so far?
We do not so homework!  But we will suggest appropriate approaches.
Message 7 of 13
(3,948 Views)
Yah in actual pipes. But how in a virtual pipes? Have any ideas?
Message 8 of 13
(3,946 Views)
So, what have you tried?  What is not working?
There are no requirements nor code that you wished to have debugged.
Post something we
Can  see,. . .
Message 9 of 13
(3,942 Views)
I havent tried anything yet. I am looking for a toolkit that i can use to apply leak on pipes virtually or visually
Message 10 of 13
(3,939 Views)
