Pivot table in Labview
I want to create the table with graph which should be act as a Pivot table.
If anybody used these in Labview,pls help me...
(4,860 Views)
Can you be more specific about what your data looks like and what you want to graph?
(4,818 Views)
Here I attached the Excel file contains data's in sheet 1 which are my inputs.
Same as plotted in chart and table in sheet 2 using Pivot.
In Ecel, When i changing the rows, colums,filters and values in pivot table , chart and table will update accordingly. This i needs to implement in Labview.
I tried to insert ActiveX object of MS Pivot Table in Labview. But I m not able to insert data's in it...
(4,808 Views)
Please show what you tried in LabVIEW (post your vi), it might help us better understand your problem.
Ben64
(4,793 Views)
In the attached vi , I inserted the ActiveX Object of Microsoft Office Pivot Table.
I do not know how to use this pivot table.
If there is any other ways to plot pivot table and chart,Please let me know
(4,770 Views)
