Place cursor in string control at start of program
How can I automatically place the cursor in a string control when I start my program.
(2,967 Views)
Use Key Focus. Popup on the string's terminal and select to Create -> Property Node. on the property node popup on it and select Properties -> Key Focus. Wire a true up to it and when it runs (near the start of the VI, I assume) it will move the cursor into the control.
Hope that this helps,
Bob
(2,961 Views)
Thank you for the answer. It works!
(2,959 Views)
