Placing a control inside a box or frame
Is there a way to place a control, or several controls, inside a box or frame such that when the frame is moved, the controls move with it?
(3,320 Views)
I assume you want this box or frame primarily for decorative purposes?
What would cause the box or frame to move?
If it is just a decoration, you could programmatically move the decoration and the associated controls the same amount.
What might be easiest is to place the controls in a cluster.  Design the cluster to have the appearance you want.  Then you just programmatically move the cluster and everything inside would automatically move with it.
(3,312 Views)
Accepted by topic author MaxYaffe
Assuming you're using LabVIEW, you can group controls and decorations using the button on the toolbar.
(3,305 Views)
Thanks.  That was what I was looking for.
(3,301 Views)
