Placing a string on the queue
Hi. I have been following the example which is called "Continuous Measurement Data Logger".
From there I have made a Modbus Message Handler, which I have attached here: Labview.PNGModbus Messange Loop.PNG
Within that .vi I have two loops, from where I, when the user clicks "Connect" I start my Modbus Master. I would from that point like to start a Watchdog loop, in order to write/read over Modbus the life bits.
Somehow, the approach of putting the string "StartWD" on the Watchdog queue, returns and error.
Any clues?
(2,711 Views)
@ChristianLiinHansen wrote:
..., returns and error.  Any clues?
  • What is the error message?
  • We can't really debug truncated  pictures.
  • Who wrote this code?
(2,653 Views)
Hi. So the issue is solved 🙂
(2,613 Views)
If the issue is solved, please post a solution for future readers.
(2,606 Views)
Yes, I was about to, but was limited as a "new member" 🙂
Anyway the solution was as followed:
1) From the template "Queued Message Handler", you need to define your new type of queue. So I went in there and added my new time.
(2,577 Views)
