Plans to abandon Silverlight?
Are there plans to replace the Silverlight-based Web interface of RT-targets?
Just ran into issues with it and Google Chrome, and the consensus seems to be that Silverlight as a technology is dead...but surprisingly I could not find much discussion about that topic here(?).
(3,564 Views)
Accepted by topic author Mads
I suspect at some point they'll phase it out as, like you say, Microsoft are no longer continuing to support it.
What problems are you having with Chrome? I use Chrome and can't say that I've had any problems with the Silverlight-based System Configuration utility.
Ah - it seems in the latest update to Chrome (I now have 42.0.2311.90 m) they have disabled all of the NPAPI plugins (e.g. java, silverlight etc.). You can enable it from chrome:flags which will then allow silverlight to work again - until another update later in the year might remove the functionality completely.
(blog)
(3,541 Views)
Here's another thread discussing this issue.
http://forums.ni.com/t5/LabVIEW/How-to-accees-the-LabVIEW-Web-Server-using-Chrome/m-p/3122242#M89651...
GCentral
(3,526 Views)
