04-02-2007 03:51 AM
04-03-2007 04:04 PM
I'll take you a step further: Instead of using a driver from a website and trying to make your own code to play your wave file, perhaps you might consider using an example vi that bypasses this all for you. This KB describes how to use the sound out vi's to play wave files and also provides you with an example vi that follows the listed steps. Take a look. I believe this will satisfy the functionality you are seeking.
Cheers,
Emilie Kopp | Applications Engineer | National Instruments
04-03-2007
04:05 PM
- last edited on
07-26-2026
05:57 PM
by
Content Cleaner
Oops!
Here's the KB [link removed; article no longer available] I was speaking of.
04-12-2007 03:23 AM
hi Emilie Kopp,
This is working...but can i do with DLLs....?
I have got the information regarding winmm.dll functions from MSDN....when Im using the same thing here in LabVIEW...i could not get the result..
I have followed the document provided "calling external DLL's in LabVIEW" but could not the result...
The functions Im using are WaveOutOpen,WaveoutWrite,etc....
can you provide me any examples in LabVIEW which use the functions in winmm.dll
Thanks and Regards,
SODLB
04-13-2007 12:50 PM
