Playing card recognition using LabVIEW and a webcam
You can invoke the Vision Assistant using the Vision Assistant Express VI from LabVIEW. When you close the UI, the code implementing the solution that you prototyped in Vision Assistant will be generated inside the Express VI, and you'll be able to use it directly from your LabVIEW diagram.
Christophe
Message 11 of 12
(1,699 Views)
Accepted by topic author vincentmees
Módulo NI Vision Development https://lumen.ni.com/nicif/us/evalvisiondevmodule/content.xhtml NI Vision Builder para Inspección Automatizada (AI) https://lumen.ni.com/nicif/us/machinevisionbrochure/content.xhtml NI Vision Acquisition Software http://joule.ni.com/nidu/cds/view/p/id/3818/lang/en
In this example, we will create a program in Labview to capture images from a USB camera to your application for further processing using the NI Vision module.
https://decibel.ni.com/content/docs/DOC-30531
Message 12 of 12
(1,656 Views)
