Plc to Labview tcp/ip communication
hello people
I was trying to communicate PLC with LabVIEW and my attempt was successfull i used modbus I/o server and communicated PLC with Labview,I would like to do the same experiment with tcp/ip function blocks but i dont know where to start
regards
ram
Message 1 of 18
(9,006 Views)
Accepted by topic author ramprabhakar26
Are you still going to be using Modbus? If you have access to the I/O Servers you should also have the Modbus API which has an example in the example finder "Modbus Library.lvproj". The API itself is pretty simple, you create a master/slave session, read or write to specific coils/registers, and close the session when you are done.
Message 2 of 18
(8,959 Views)
What PLC are you trying to communicate with? Also, what Protocal? Most PLC's today can open UPD sockets,
Message 3 of 18
(8,945 Views)
Hi dave
Thanks dave for reply im using schneider tm218 plc for this experiment
Message 4 of 18
(8,927 Views)
hi jacobson
Glad to see a reply, can you elaborate procedure a bit.
i followed this procedure https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0QgCAI&l=en-US
thanks
Message 5 of 18
(8,924 Views)
hi,
    what program u wrote in inside the PLC and which one is master and what is method you use oil or register type.
Message 6 of 18
(8,918 Views)
hi gokul
i just wrote a four way traffic program
and i followed this procedure https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x0QgCAI&l=en-US
Message 7 of 18
(8,896 Views)
hi,
    best way you can use modbus library.
                                    http://www.ni.com/example/29756/en/
Message 8 of 18
(8,892 Views)
hi gokul
thanks a lot for reply but imusing labview 11 i couldn't open a vi that you sent me
can you convert to Labview 2011 and send me
Message 9 of 18
(8,883 Views)
Here is the Modbus Library. I use this instead of a I/O server. Gives you more control for the communication.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LP9SAM&l=en-US
Message 10 of 18
(8,863 Views)
