Please! I need a solution to read the running max-min
I am a starter and not too good in labview. I need to read the running max-min as the random numbers are generated in the loop. iam not getting it right. I have attached the VI. Can anybody please help me making it right???
Please Please Please!!
CL
(2,628 Views)
Your code was somewhat confusing, it was hard to tell what was going on since the upper and lower kept flip-flopping (try to keep mins and max's seperate).  This is *almost* the same code you submitted, just cleaned up a bit more.  Remember that you want to initialize to the first value that comes out of the random number generator, since that will give you a real minimum since the generator may never reach the initialized minimum that you set (which in your case was zero, I doubt the generator will ever return true zero).
-Danny
Message Edited by texasdiaz on 09-26-2005 02:44 PM
(2,613 Views)
I think this is more what you're looking for. It creates an array of numbers and appends a new element with each iteration. The Array Max and Min is then used.
(2,609 Views)
