09-26-2005 09:52 AM
09-26-2005 10:06 AM
09-26-2005 10:13 AM
Hi LW-s
I've just modified your code to perform the required function.
Hope this helps.
09-26-2005 10:32 AM
09-26-2005 10:33 AM - edited 09-26-2005 10:33 AM
Since you are using LabVIEW 6.0, I cannot attach an example that you can open.
Just take the square root of the absolute waveform, then multiply by the original sign of it. No case structure needed. 🙂
Message Edited by altenbach on 09-26-2005 08:33 AM
09-26-2005 10:39 AM
i couldn`t open the file you have attached probably because i am using labview 6.0.
would you please send it again in labview 6.0 format?
09-26-2005 10:44 AM
would you please send it again in labview 6.0 form?
09-26-2005 10:50 AM
09-26-2005 11:08 AM - edited 09-26-2005 11:08 AM
Maybe 6.0 has some restrictions on waveform math. You can always operate on the y values directly, similar to GerdW's suggestion. (Note that you don't need to deal with the other elements of the waveform.)
Message Edited by altenbach on 09-26-2005 09:08 AM
09-26-2005 11:10 AM
i just tried and it worked.
thank you very much for your help 🙂
