Please check the wiring of the code
Hello All,
I am attaching a code . Please check the wiring of the code in the section where initially the 2 simulated triangular signals are added. The output is of dynamic data type and I have added it along with an integer type. Is that correct? Coz the thing is that I am getting the desired result with the code, but just wanted to confirm the wiring of this particular section.
Many Thanks,
(2,816 Views)
The addition part is mose likely done good.
You should however check the error in out of the adder, if the dynamics types mismatch you get an error there.
Ton
My LabVIEW Ideas
(2,814 Views)
What if the error is zero...that is what I have assumed, then wat?
(2,807 Views)
You should check the boolean and not the number, however a number indicates there is no error.
Ton
My LabVIEW Ideas
(2,782 Views)
