Please convert 8.0 to 7.1 !!!
can anyone convert my 8.0 *.vi files to 7.1?
8.0 file was converted by 8.2 and I hope it could be opened in LV 8.0.
It does not matter for me if convertion will not fully functional but I need it in any case.
And it is very important for me to get this converted file before 05.04.07
Big thanks in any case.
Message Edited by bormental on 04-03-2007 01:11 PM
Message 1 of 10
(3,677 Views)
Could not open your VI
can you re-attach it??
Message 2 of 10
(3,653 Views)
Hi opened your file
but there are 3 files missing:
xy chart buffer
FFT subvi3
Array of counts 2
so unable to help
xseadog
suggest you save all vi'sin a library, make sure you make main vi as start vi
xseadog
Message 3 of 10
(3,644 Views)
That's a pity.
In attachment are two files 82.vi (LabView 8.2 version) and 80.vi (converted with my friend LV 8.0 version of 82.vi).
More important for me to have structure of my project and doesn't matter that all subvi inside of 82.vi (80.vi) be opened. Please spend your time to help me one more.
Big thanks in any case!
Message 4 of 10
(3,644 Views)
Hey
your request was for a convertion.
This can only be done if all vi are present !
tak
xseadog
please also remember that several functions in LV8 or LV8.2 cannot be recompiled backwards to LV7.1
Message 5 of 10
(3,641 Views)
Mmm, I'll be more smart next time, may be.
Thanks a lot!
Message 6 of 10
(3,638 Views)
So
logic would  not presume that you have achieved your object
or did I miss something?
xseadog
Message 7 of 10
(3,620 Views)
xseadog, how were you able to open the vi? I got the follow error msg
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 8 of 10
(3,617 Views)
Hi
I only opened the 8.2 version, the resquested files were still missing.
Built dummies then realised that he would not be able to run application with a mixture of different versions so dropped 'immediate'support
xseadog
Message 9 of 10
(3,613 Views)
The problem is that I'm sitting now at other computer with other LV in other country...
And I need my project 82.vi just as example for absolutly other project.
So  in my situation I'll be glad if I get pdf or jpg copy of work diagram.
I now diagram looks awful but can anyone make some screenshorts or generate pdf from my project diagram,please?
Kind dummy.
Message 10 of 10
(3,596 Views)
