Hi Dennis,
Thank you very much for your help in (successfully) trying to download and extract the zip file, and for your fast answer!
Yes, you are right two times:
First: The zip file is OK.
The fault has to be an incompability of the zip file format used by NI with my 6.2 version of Winzip. My Winzip program still pretends that the zip file contains two files of the lenght zero whereas another (newer) unpacking program (Ontrack PowerDesk) was able to extract the two files correctly.
After over 10 years of using zip files this is my very first experience of an incompability of zip files with a pkunzip/extraction program. If I had known before that these problems exists - without any notification or hint from the unpacking program that there is a
file problem or a file format incompability - I would have tried another unpacking program initially.
And, yes, you are right a second time:
My message has obviously - and by mistake - been posted to the LabVIEW users discussion forum.
I wanted to send it to a NI employee, but somehow the NI web form has led me to the LabVIEW users discussion forum, despite the fact that I have chosen the radiobutton "to a NI engineer".
However, you solved the problem. Thanks again for that!
Au revoir,
Martin
