Please help me solve this command
Dear NI Community
Could you help me create a command on service mode. This program create for test IMU. I already sent example of this program. Please kindly see attached file.Service Mode Labview.JPGService Mode Labview.JPG
This is example block diagram that I already create on Labview program
Currently I need to create a Erase command and Save command for run in service mode.
This program design function similar to Sensornor Program STIM210 EVK.
Spoiler
Thank you for your help.
If you want any other information. Please told me.
You can contact to me via email : PK@autorient.com
Phakhawat  Ketkaew
(2,779 Views)
Hi Phakhawat,
Add the command description to the "available commands". Then add a new case to the case structure in your image.
What have you tried? Where are you stuck?
Where did you "sent that example" to?
On your image:
Do you really need a timeout of just one millisecond?
Do you really need to read a serial port 500 times with a wait of 500ms?
Do you really need to use BytesAtPort?
(2,765 Views)
