Please help with NI installation issue of LabView and NI Max
My name is Piyush and I use LabView and NI Max to run automated tests in my company.
I am contacting you regarding an issue I faced while installing the NI Package Manager for LabView 2019 and some more NI applications on a PC.
I am going to need LabView and NI Max for my test setup. As I proceeded to install the NI Package Manager, it only allowed me to select the LabView version 2024 Q1.
We use LabView codes that are compatible with the LabView Version 2019. The codes may not be compatible with the later versions of LabView.
Could you please help resolve the issue and help set up the LabView 2019 and NI Max?
I have attached screenshots of the issue faced and the LabView version used on other PCs for the test setup.
LabView Version on other PCs
Thanks and regards,
Piyush
(663 Views)
(653 Views)
